Hello,
I have a 1999 Lund Tyee with a 4.3L Mercruiser. I just installed a Lowrance Sonar/GPS. I wired it to a 10 amp accessory fuse, so I could cut power to the Lowrance when the master power switch is turned off. My stereo is also wired to the same accessory fuse.
My problem is when I turn the blower on, the Lowrance shuts down. I've noticed my trim gauge also drops when I turn on any accessory, lights, bilge, blower, stereo, etc, if the ignition switch is off. If the blower is already on and I turn on my Lowrance, it stays on OK. I'm guessing there must be a surge of power to the blower when starting it, causing the Lowrance to drop below what's required for it to stay on. I wouldn't think those little blower fans would required much power to run them.
Any ideas where I might start troubleshooting?
Thanks
Thanks
