lowrance updates
captn-tin
i checked my 332c unit to make sure it has the most recent update 1.6.0... it does. is there any way to check the lgc-2000 module to see if the lgs-2000 1.7 code is already in, or can i presume that being the 332 code is up to date, that the gps module is too? thanx in advance....Bill
tommays
Re: lowrance updates
MENU<br /><br />NEMA 2000<br /><br />Bus Setup<br /><br />All the NEMA 2000 devices will show up here<br /><br />Your suposed to flash the LGC FIRST it is a different file than the 322 update and will not be updated unless you did it :) <br /><br />
Note: If you have not already done so, please update your LGC-2000 GPS module with the new LGC-2000 1.7 code before updating this unit with its latest code.
http://www.lowrance.com/Software/Upgrades/LMS/LMS-332C_160/Default.asp <br /><br /> http://www.lowrance.com/manuals/Files/NMEA2000NetworksGeneralInfo_0154-172_101005.pdf <br /><br />This is a much better nema 2000 guide than the manual WHICH i am pretty unhappy with :( <br /><br /><br />tommays
