lowrance
OllieC
Re: lowrance
One is probably for the transducer cable and the other is for 12vdc
GA_Boater
Re: lowrance
One is the power/transducer. The other is for a speed paddle wheel and temp. Do you have the manual?
WIMUSKY
Re: lowrance
What Ollie said, one is for power and the other for the 'ducer. Temp sensor is in the 'ducer. I don't believe that model has a speed option....
GA_Boater
Re: lowrance
Now we need the OP to tell us which model Elite-4X he has. There are only about 10 different ones. Sonar only, Sonar/GPS, HDI, etc.
The connectors change depending on which model. On mine, the power and transducer with temp are through one of the connectors. I don't use the other one.
