OptsyEagle
- Sep 13, 2006
- 1,364
Well I am in the process of changing the seals on my motor and have come to two roadblocks where I could really use some advice.
The first is; I can't seem to slide the bearing head off the prop shaft. It slides on the shaft OK but stops at the end. I don't know if I am just supposed to pull really hard or if I need to do something else to get it off. I want to change the seal around the prop shaft and do not want to break anything.
The second issue is getting the shift rod bushing out of its hole. Has anyone gerry rigged up a tool to punch it out or pull it out, so the O'ring can be replaced. Again I do not want to ruin this busing but it seems to be in there tight.
Any help on one or all of these issues would be surely appreciated.
