Lube Drain on Outdrive Tough to Get Off
MercMonster
I tried removing the drain screw on the outdrive and it is stuck in there tight and somewhat stripped by previous owner. Any tricks or hints other than drilling it out?
Haut Medoc
Re: Lube Drain on Outdrive Tough to Get Off
Use an impact driver with a fat bit.......;)
njlarry
A big fat screwdriver with a pair of vice grips worked for me. Replaced it with an allen wrench plug.
Don S
