lube for rod and main bearings
les morgan
Seloc manual says to use a gasoline soluable grease when installing rod and
main bearings. What grease/lube do you recommend?
saumon
Re: lube for rod and main bearings
A special "Needle bearing assembly lubricant" or simply some Vasoline (petroleum jelly). Anything that will provide adequate lubrication at start-up AND that will dissolve with gasoline.
