rodrigwa2005
- May 8, 2005
- 11
Here I go - I decided to get away from paying someone else to do this for me - downside is I am rookie so I am looking for some help from more seasoned boaters.<br /><br />I got a Alpha One 3.0 LX, I/O, Mercruiser transom, '97 with power steering.<br /><br />Specific questions I have are:<br /><br />- On lubrication for the power steering unit - I keep looking for the lube fittings ( manual indicates the use of Quicksilver 2-4-C marine lubricant) - can't locate them - All I found were orifices ( flushed with the body of the unit) plugged with what looks like tiny bearing balls - nothing close to look like a lube fitting - Any suggestions?<br /><br />On the engine coupler - Manual indicates "lubricate every 100 hours or every season with Quicksilver engine coupler spline grease" - help required is: How do I access the lubrication points?<br /><br />Thanks in advance.
