All right guys, I'm worried about hurting my outboard. The boat is a custom built OB17 center console v-hull designed by Bateau. It has a 70 hp Yamaha 2 stroke (2005). The boat wieghs approx 1500 lbs with 2 adults on board, full tank and gear. I'm running a Turning Point aluminum prop 13.25x17 and hit 5100 rpm at WOT at 35 mph. I do have a problem with porpoising (around 4500 rpm) unless I keep the motor trimmed all the down at wot. Normal cruising on plane is about 22-25 mph at 3500-4000 rpm. Am I lugging the motor at those loads and rpm? I believe I would get a few more rpm's if I could trim the motor out. The AV plate is even with the bottom of the hull and on the 2nd hole. Would moving up a hole make a difference and should I change props?
Any help would be greatly appreciated.
