I just bought a '98 Tracker pro team 185 with a 90hp Merc (90ELPTO). I am only getting about 4700 rpms at WOT trimmed all the way out. Just wondering if I should address this lugging issue by lowering the pitch of my prop or raising the motor on the transom. It has a 26P 3 blade SS prop right now so Im assuming I can get the rpms up by dropping down to around a 22P but seems like I've read that propping down isnt always the best solution if the motor is mounted too low on the transom (its mounted thru the second set of holes from the top of the bracket). Also I am only running at 39mph GPS at wot so Im thinking propping down will lower my top end speed (yet raising rpms) but I would think that this boat w the motor propped and mounted correctly should do 40-45mph at 5500rpms (i could be wrong).
Also water does come over the splash well when stopping/coming off plane (I just nudge forward to out run the splash)...is this a symptom of an impropper motor/prop set up as well? Thanks
