What is lugging a motor? I've been reading threads and someone mentioned that with the wrong prop you can kill your motor. I'm looking to go from 11 3/4 x 19 to a 13 x 19 by the recommendation of a Mercury dealer, salesman, and a prop calculator I found online. My prop died and they didn't sell a 11 3/4 and started looking into the correct prop for my boat. What would the symptoms be? If I can't get to wot rpms is that lugging? Would you expect to see with the change in diameter prop? I believe I had to much throttle with my old prop. Meaning I never had it all the way forward or it would exceed the 5200rpm. I also only run it by myself so I didn't know if that was normal.
Thanks
Thanks
