Can I raise motor on this boat? It has a lip on the top of the transom and motor will not be flush with the transom. Can I do something myself without a dealer? Dealer who sold me that boat is 2+ hours drive and I prefer to do this myself. Problem I am trying to solve is ventilation when trimming to max speed (vent plate not level at max speed + I am getting ventilation with slight turns). The vent plate is level with bottom now, I tried other prop but it did not help much. Boat handles good at lower trim but speed is lower by 3-4 mph. The max I am getting with max trim (and ventilation issue) is about 42 mph. To get good stability without ventilation I should go 38-39mph.
PS I had tried Michigan Apollo SS prop with same pitch I have (21) but it's a bit bigger in diameter (+3/8") and I think it felt a bit much for my engine. Also I calculated slip for prop ~0.05 seems a bit low?, is Apollo XPS actually not 21 pitch but somewhat more? It game me a bit better handling but RPMs are on low range (~5100 of 5000-6000). It seemed like if I raise the motor I should get better RPMs (at least in theory).
Thanks!
Thanks!
