M40c tohatsu
Dbuck
little rough on low idle rough on acceleration then lines out. Cleaned carburateur need a little help with this. Would really appreciate some advice,Thanks
pvanv
What method did you use to clean the carb? Did you check link and sync? Did you check ignition?
Sea Rider
Welcome to Iboats,
Was doing so when on muffs, barrel or on water ? Lines out means OB smooths out when opening the throttle ?
Happy boating
TOHATSU GURU
Not a smooth running model engine so,it may be normal. Pull a spark plug off of one cylinder while the engine is running to test for a reason why it may be rough electrically or mechanically. Otherwise you take the carb off and clean it as a first step.
Sea Rider
If carb was cleaned to prfection, check carb/timing advance synch, re adjust if needed. Check that all plastic bits from throttle arm to carb are not worn out as to have excessive side or up/down play for a smooth and even acceleration. Replace any if required. Check spark plugs condition, if old, excessively burnt or fouled replace both. KGK BR7-HS-10 with electrode gapped tight to 1.0 mm with feeler gauge.
Happy Boating
