locofisher
- Jul 9, 2009
- 5
I have a Jabsco macerator that I installed last July and it worked flawlessly until the other day. It quit working from one day to the next. I started with the routine troubleshooting making sure I had power to it. I check the connector with a multimeter and found out I do have power. I went ahead and cleaned the connector and reconnected it and still, nothing. I finally took the macerator out and hooked it up directly to my car battery and it worked as advertized. I've checked fuzes, switch, and decided to resintall it without a push pull type connector going with butt connectors instead....still nothing. Does anyone have any ideas? I have power to the pump but it won't work and when I hook it directly to the battery, it works. Could it be a ground? I figured though that power wouldn't register on the multimeter when touching the red and black wires with the corresponding multimeter leads if I had a bad ground.
