I ran it at wide open for at least ten minutes.
Before I did any work on the jets, I rebuilt the fuel pump, as the original diaphragm was still installed. It made a difference, but did not fully solve the problem.
I talked to Franz Marine on the phone. They didn't have any of the jets I needed, but could have them made. I decided to modify mine before I went that route. Thanks to Franz Marine for their prompt response to my inquiry, though.
I bought some drill bits online, both #50 (.070) and #49 (.073). My original thought was to lock the jet in my Workmate, and drill the orifice out, but I wasn't sure I could control the process. I ended up locking the bit in the Workmate, and slowly reaming the orifice out by hand. It worked out pretty well. I reamed to .070 first, then went to .073.
After re-assembling everything, I fired it up and ran it for a while. After a few minutes, it seemed to smooth out. I also adjusted the idle needles, so it idles much better, at least on the hose. I'll get it in the water sometime next week and give it a workout.
Pictures of the jets and reaming process attached.
