Gonefishing760
- Jul 17, 2016
- 7
The main fuse on my 1995 Mercury 40hp outboard keeps blowing. I've searched the boat and motor for any frayed wire that would cause a short. I even rewired the ignition switch that looked suspect. We would replace the fuse and run the engine one of us would watch the fuse and the other would start wiggling wires searching for a bad connection and nothing. We found that the fuse would only blow when the boat would be running at 12+mph. Which leads me to believe the voltage regulator is suspect it has a direct connection to the fuse so I can only guess the voltage builds as the Rpms do and the fuse pops because of a faulty regulator. Am I crazy or does this make sense? Any suggestions would be great.
