main nozzle issues
Joe Dirte
I pulled the top carb to kit it and am having trouble removing the main nozzle, shouldnt a screwdriver do trick with minimal force?
Frank Acampora
Re: main nozzle issues
The high speed jet is in relatively tight and will "snap" or "creak" when it breaks free. You do need to give it a good grunt sometimes.
Use a 4 way screwdriver with the big flat blade tip. It fits the slot in the jet closely and prevents buggering it.
MickLovin
Master Chief Petty Officer
If some PERSON before me has buggered the pipe coming down through the main nozzle (as in bent the end over) will i have fixed it if I have re-opened it with a same size drill bit? I didn't drill it, I placed it up it and opened the hole.
jerryjerry05
Don't take em out.
No need to remove unless your gonna re-jet
