maintenance help
hitace
have a 150HP 2001 johnson 2 stroke outboard and needed to know everything to do for general maintenance?just need to know everything to change and clean. is it the same as a car tun up?
hitace
Re: maintenance help
oh and it is carburated
tashasdaddy
i sugggest you contact a dealer, and get a owners and service manual. too, numerous to do on line.
Silvertip
No -- maintenance is not the same as a car. You are asking for lots of detail -- all of which is included in a service manual for your engine. Routine maintenance covers many topics from simple spark plug replacement, lower unit lub chanage, carb rebuilding, water pump impeller replacement, link & sync, charging system and fuel system checks, etc. All of those procedures are relatively easy if you can follow a service manual.
