MalibuMike
- Dec 29, 2020
- 137
I had my boat out recently and saw water entering the engine bay but did not know the source. I read about a technique where you fill the hull with some water and look for leaks under boat. Well, that worked really well! I found the leak at the brass plug. I see that it is threaded in with three screws. I'm a little afraid to take it out since I dont know what is involved with maintenance. I could use some advice on what type of sealants to use in the screw holes or around the plug. In the event that the screw holes are stripped, I'm assuming I would just rotate it a bit for new holes. I would like to hear about how to install new holes if needed. Do I pre drill? Coat an exposed wood with epoxy? Any advice would help.
