Thanks for the welcome, and thank you both for these great insights. This is so helpful.
When I got it winterized, they found some water in the gear oil, so that has been changed, but I’ve taken he unit in for pressure testing to see what seals need attention. I’ve asked them to do the impeller while they’re at it. Hopefully the situation isn’t too bad there. I took off the cap and inspected the gears, and they looked good, with no corrosion. The bellows were at the end of their life, so maybe they were the culprits there...
I’m grateful for the advice about manifolds and risers. It’s been a freshwater boat all its life, I believe. Any advice on how to inspect those?
You’re right, I do need to get hold of the manuals. Are they available online?
The one other thing I’m looking at is some play in the steering. I’ve concluded it’s not down at the transom end, but is in the steering console at the helm. The wheel just moves a little before engaging the wire, I think. It’s a quicksilver ride guide rotary rack and pinion (yes, it says both on it!). The thing turns smoothly and pretty easily, just has that bit of play. Any advice there?
Thanks for any and all wisdom in the project!
