We have a 1996 Maxum Mercuiser 3.0L. We have been using it just a few hours a year for several years. How often should I change the engine oil and filter and also the gear oil? What is the recommended gear oil?
Thank you in advance for your help.
I do it every year whether it needs it or not. Any brand lower unit oil is fine.
your supposed to change the oil every fall prior to winter storage, or every 50 hours. which ever occurs first
Do I suspect the oil and filter have not been changed in those "several years" which is why you are asking now? Changing gear oil at the end of the season (or any time during the season if you boat year around) gives you the opportunity to see if the seals have been compromised -- as in a milk shake appearance to the oil which occurs when water mixes with the oil.
+1^ I change my engine and outdrive oil every spring. Cheap insurance in my books. I use Mercruiser lubes but that's not to say others aren't as good. Just my preference.
