maintenence ,260 hrs.what to do?225 yamaha
arthur B
ok, last year I bought a 2005 key west with a 225 yamaha It had 200 hours on it I ran it most of the summer no problems i didn't winterize just cranked it up and let it run for thirty mins. once a month,I live in savannah ga. didn't get too cold,what do i need to do now? it has 260 hrs. when i bought it the dealer said it was serviced at 200 hrs. but did not have any real details any suggestions will help
reelnative
Re: maintenence ,260 hrs.what to do?225 yamaha
Hi is it a 4 stroke or 2, at the least you should change out your lower unit fluid, ck or change out your plugs ck all your lines and cables for wear, change out your water sep filter, greese all your zerks ck filters on motor and change if they look bad greese your steering , pull your prop and ch for any debris and greese your shaft, might even want to go to a dealer and have them hook it up to a computer and see really how many hrs are on it, and if any codes come up, and if its a 4 stroke you will need to change out your motor oil and filter also
reelnative
one thing I forgot to add is they want you to change out your waterpump impeller once a yr but every other yr prob would work, I guess it would depend on how much you love running into sandbars
