Hello all. I just finished a restoration project on a boat that sat for about 6 years. The motor is a 1972 Merc 1400 inline 6. I have drained and cleaned the fuel tank. Rebuilt all three carbs. Changed the water pump and base. Put in new spark plugs, lower unit oil, etc, etc. The motor purr's like a kitten. I just got back from the first trip with it. Started out great. The motor starts in about 1 second even when cold. When I took off, the motor cavitated (sp?) while trying to plane. So I backed off a little till the boat planed. I was then cruising at about 4800-5000 rpm only for a couple of minutes taking it easy, then it just stalled while under power. It started right back up, but now it will not run past 2000 rpm at WOT. I checked all fuel lines, filter, carbs. The carbs are opening all the way. The choke is ok. We tried to advance and retard timing while driving, tried to pump the primer, we checked all cables to ensure full throw..................................Everything was just where it needed to be except for the speed. The high idle lever will rev the motor upto amost 4000 rpm, but no luck getting that under a load. Any suggestion will be greatly appreciated, since I had spent numerous hours trying to get this boat ready for this past weekend only for it to fail. Thanks in advance, Joey
