Make more parting it out or selling it whole?
Newbie@boats
If I resleeve the cam and do all the new seals and it does not fix the weep hole and over heating problem I think I am going to part with the 470.
Would I make more money selling the outdrive/motor/boat/trailer seperate?
Should I just try to sell it whole?
The outdrive works perfectly, with a new impeller.
The motor runs perfectly, besides the over heating problem.
The trailer is galvinized.
The boats hull is solid, and is set up for fishing.
What numbers would I be looking at for the motor/outdrive/trailer/boat?
Just trying to make back what I have invested into it if this does not fix it.
Thanks
Bt Doctur
Re: Make more parting it out or selling it whole?
It has no bearing on the overheat condition , that would be impeller in the drive ,clogged riser, heat exchanger ,stuck thermostat,etc.
Newbie@boats
I got a new T stat waiting to get put in, I checked everything, I flushed everything, I just have to wait for the sleeves to come in then I will be putting it all back together, flushing it out again, changing the oil, and hope for the best.
