MartiMcFly
- May 5, 2025
- 2
Hey everyone, I have a 1992 Mariah with an Alpha 1 Gen 2.
The trim pump/motor is a SAE J1171 Marine, with the yellow cap that has a hole in it for self venting.
There is water in the system (that appears to have entered through the cap) and I am needing to clean it out, when I raise the trim it is very slow and but does suck oil, when I go to lower it, fills the reservoir with milk And drops at normal speed.
Process:
Process:
- Bleed Lines
- Lower trim and place a piece of wood under to allow trim to rest
- Remove the lines from the lower unit
- Fill reservoir with fresh 10w-30 or 10w-40
- Run trim up, until lines push clean fluid
- Run trim down, until lines push clean fluid
- Bleed Rams
- Remove both rams marked for sides
- Pump the ram multiple times to remove fluid
- Add fluid to ram and pump ram
- Refill
- Reattach lines to ram with trim lowered
- Keep reservoir topped off while raising and lowering the trim
- Remove pump reservoir and clean (might get contaminated in first steps)
- Do I need to worry about the trim “stops” does any of this reset it?
- I just want to use fresh oil to flush, I don’t wan to use any solvents
