I seized up my Johnson 1976 25hp awhile back. I was able to get the exact power head from a vendor. Since I got the replacement I did all kinds of work, thermostat, rebuild, carb, fuel pump etc. I decided since its apart I should drop the lower unit, and change impeller. In doing so I had to remove a small door to undo shift lever. This has a gasket. Problem is I really don't want to order a $1.41 part and pay $8 for shipping. Can I use a silicone style gasket maker? If so what should I use? Also, there is no gasket between the lower unit and the upper/exhaust portion. Should I use the same gasket maker if any?
Thanks
Thanks
