Making sure...
MrPhotographer06
How can i make sure that i've got enough fiberglass on the back corner of my transom?
Tomorrow i plan to bondo over the low and high spots and get the top half the boat back on.
But i dont want to get everything back togeather and the first time i put the boat in reverse and go forward it breaks off
jcsercsa
Re: Making sure...
Hi there ,
Well frist we need to know how layers you have put on ?? fiberglass that is ???
and second bondo isnt good to use on a boat , it not water proof !!!John
ondarvr
Re: Making sure...
Skip the bondo, it won't hold up.
If all you have is mat on the transom (like you said in the other post) then you need some roving in there for strength.
MrPhotographer06
Re: Making sure...
this is short strand fiberglass bondo filler
and i've got 1layer of mat. then 1 cloth.. then 1 mat..then 1 cloth.. then 2 mat...
i plan to sand the top layer of mat down.. decently flat.. then lay that short strand over it to act as the gell coat so then its flat..
jcsercsa
Re: Making sure...
what is the weight of the glass?? with 4 layers you should be good , and on the bondo , from what i have read on here it allways been peanut butter or marine tex !! what are you doing with it ?? John
SuzukiChopper
Re: Making sure...
I don't think that short strand will act as 'gelcoat' like you think it will. From what I remember of it and from what I've read, it's very similar to taking CSM and chopping it up in to your resin. Will act as a filler and is pretty much pre-made 'peanut butter', but isn't gelcoat. Just make sure the bondo stuff you're using isn't automotive putty mixed with short strand, make sure it's the fiberglass stuff.
BWR1953
Re: Making sure...
My dad used to have a rule of thumb:
If some is good... more is better... and too much is juuuuuuust right! :D
-BWR
MrPhotographer06
Re: Making sure...
well my fiberglass work is thicker than the old including gell coat so it should be good
