Manifold and riser change gasket Q’s
Hey folks. Long time google lurker. Thought I’d join. We bought a 1990 bayliner 20 footer and it has a 4.3 mercruiser serial#0D382045 and it has a cracked manifold. Two manifolds and risers on the way and wondering if the gaskets are dry fit on the block and between risers or do I need some anti seize/lube there?
also, any tips on cleaning the surface and avoiding contamination of the block ports ?
get good gaskets (not sierra brand)
install dry
bolt manifold to head
bolt elbow to manifold
if your head gasket surface is rusty, hit it with a wire wheel and a sanding block
any sanding debris you get in the block ports will come out when you fire up the motor.
