Manifold and Riser Question '73 120hp
oceaninabox
Ok, I think I bit off more than I can chew.... BUT!!!! Anyways, do you guys think this Riser is still useable? I took the manifold off because it was cracked and in the process thought I would clean up everything else that I could. When I took the riser apart this is what I saw. I realize there is a lot of cleaning left to do, but Im just curious if the riser is still useable. To me it looks like it's cracked on the "O" part of the inside. What a mess it was inside the manifold. Im surprised it evan ran, but it sure does.
jerryjerry05
Re: Manifold and Riser Question '73 120hp
Go new.That looked cracked. You probably couldn't get it to seal right again.
Osco makes agood replacement and cheaper too.J
