1975 Johnson 135
I had the engine on the muffs and while it was running I noticed a little bit of fuel coming from the bottom right corner of the air silencer plate. The manual says this is a check valve. There is a hose connected to the bottom right corner of the manifold. Does this mean my carbs are flooding??? Or is the check valve bad?
I took off the carbs and found some small hunks of dirt in the lower carb float bowl, so carb kits are on the way.
The manual says a bad check valve could cause a misfire in the engine.
I have been chasing the "put in gear and stall " problem and wondering if this could be the cause.
