Manifold replacement
RomanRegal
Hi,<br />I am going to replace the manifold on my 1987 5.7L 350 SB, 4bbl. I did an upgrade on the carb at the beginning of this summer. Out went the Rocheester quad and in went an Edlebrock 600cfm. A little high in the compartment. Any used an Edlbrock manifold and how hard is the repalcement. Thanks Roman
Elk Chaser
Re: Manifold replacement
It's not too hard for someone with some mechanical ability. If you can swap a carb you can change the intake. Just pay attention to where everything goes including bolts and you will be fine.<br /><br />This link will help some, it's automotive but the principal is the same.<br /> Intake Manifold Swap
snowmon
Hi,<br />Make sure you mark the position of the distributor before you remove it.<br />Snowmon
