Manual Choke Kit
icdoo
Hello All, I have an 1988 invader with a 2.5l mercruiser. I has 2bbl carbs, I think Rochester..... Does anyone know of a manual choke kit that I can order? Prefable an electronic one that I could just add a button up at the controls instead of a cable.
I don't like this bi-metalic heater setup, I would like to be in control.
Any input would be great
180shabah
Re: Manual Choke Kit
What are you trying to accomplish?
Is your current setup adjusted properly?
icdoo
I would prefer a manual choke, so I can control it based on need, not based on best temperature guesss.
Ayuh,... There hasn't been Manual chokes on a boat in 50 years...
HT32BSX115
I have an electric choke on my 454. I never connected it. I don't like chokes since they just make the thing run rich(when cold). It's not needed once it warms up.
I don't run the engine in cold weather so I really haven't had a problem running with it disconnected.
Your mileage may vary.
abj87
I hate manual chokes, the cables get rusty, the linkages are cheap seel. fix the auto choke and you'll be fine. I have NEVER run into a situation were i needed to override the auto choke. Boat Starts up in 35 digree weather and after 30 seconds it will idle soothly.
icdoo
Ya I did not want to use a cable., just a solanoid with a push button. Anyways I fixed mine, I still would prefer a manual choke.
