manual for 1965 evinrude 6 horse fisherman?
tashasdaddy
brp-evinrude, parts & access. lower right there is literture, click there and it will take you the the site for the factory service manual. which is best , a little pricey, but worth it. it uses 50-1 fuel mixture and plugs are J4C gapped at .030
ezeke
Re: manual for 1965 evinrude 6 horse fisherman?
http://www.boatsetup.com/SparkPlugChart.pdf
Try kencook.com or maxrules.com for the factory service manual.
Everything in the owner's manual is in the service manual. Search ebay for "6hp service" you can probably snag a used one. Johnson and Evinrude are mechanically the same in the 1965 6HP models
The BRP site doesn't have the 1965 and it is a little different from the 1966 on.
CanWoodsman
Seloc also offers a manual for this motor.
Johnson/Evinrude Outboard Tune-up & Repair Manual Vol. 1
ISBN 0-89330-007-1
tashasdaddy
oem is better than seloc, seloc is better than clymer. intec is better than clymer. anything is better than clymer.
scooter73
I:ve got a 6 horse evinrude i don;t the year of it the numbers on it is 6502m-e03156 It keeps fouling plugs run fine with new plug as soon as you shut it of and try to start the plug are fouled
