Re: Manual locking hubs on 4X4's
I HATE when one wheel is up the the hub in mud, and the other is not moving. I bet a limited slip would be enough, but I heard they can still act like an open diff, if one wheel is in really soft mud.
But prob good enough for most off road situations.
you have a gmc scott?
I have a Cummins powered Dodge Ram 2500.
The "open" differential end's when the front hubs are locked, locking both wheel's (axle shaft's) to the spider gears and to each other. The front diff. is no longer "open". Your dodge ram has an open diff. until you put it in 4 whl. drive. How does your truck turn in 2 whl. dr./vs 4 whl. dr??? In 4 whl. both front wheel's are locked together unless something is wrong with your truck.
The "simple" video is not showing a 4X4.
Wrong, you obviously missed the whole point of the video, The spider gears freewheel, allowing both axles to differentiate. Sorry, you do not understand how it works.
The reason you feel drag while turning in 4wd is because the u-joints on any given side bind up, not because the fronts are locked together.
Beleive me, if you drove my offroad rock crawler, you'd really feel the difference, and that's the reason I put full hydraulic steering on the rig.
Not sure why y0u are debating this point, I do know what I am talking about here
If you look at the video I posted previously, it shows how a differential works in the simplest of terms.
My rig is locked in the front in 4wd
This is my tow rig, and NOTHING is wrong with it, it has an open front diff, just like ALL street trucks.
