manual release ?
misdeal
i have a 1989 120hp johnson outboard, trim/tilt motor quit with motor all the way down, is there a maual release to raise the motor ?
jonesg
Re: manual release ?
Yeh its typically on the side, look for a hole in the side bracket, there should be a screw inside there, mine was filled with barnacles and hard to see.
Use an impact screwdriver to loosen it, they are usually in there very tight.
The valve is retained with a springclip, leave that and just loosen the screw a couple of turns, thats all you need.
