Metalwizard23
- Jun 30, 2018
- 50
WEll I got a NEW TO ME boat.. its actually a BEAUTY took her out firs time this morning and ran into some typical bugs..
BIggest issue is SHIFTER..
Its a CABLE shift the boat is 1982 250 HP OMC
First got it on the water and it seemed to shift into gear ok..
Ran it around a few laps to burn out some crappy fuel and she runs Good..
did some fishin ran it around some more.. ran good.. (she's fast too I love it hit almost 50 was really surprised)
took it back to the dock... having some idle troubles (holley carb that i did go through) did some adjusting at the dock.. could not get the idle down below 1000 rpm.. though maybe I should go for a few more laps clear out some more of the crappy fuel (it sat for 4 years before I bought it.. had a few gallons it it filled it up with 91 ... about 15 more gallons)
well this time I went to put it in reverse.. and it would not go I had to get the rpms up to 2500 before it would go into gear (not good) tried forward and just about as bad.. then after trying to go back and forth I almost could not get it in gear..
took it home opened it up and the unit on the back for the shifter seems ok.. BUT I pulled the cable and I could not really move it by hand..
checked the oil level in the lower it was a little low ( put about 8 to 10 pumps in it) tried shifing again.. could not move it by hand BUT with it connected I COULD move it into forward and into revers BUT reverse was REALLY HARD Shift.
I have an old OMC manual for my ELECTRIC shift but it has nothing on these cable shifters.. anyone have a link to some good info on this thing?? I looked at youtube and found NOTHING that looked like my setup.. (its WHITE with a lever on the front and markings on how far into gear you are)
anyways I hopeing someone could steer me in the right direction
EDIT: Ok what I have found is this is NON hydraulic Mechanical shift. I cant seem to find anything EXCEPT how to remove the cables... nothing on adjusting them.. or if theres a shift problem
