manual to electric
leaker
have a 1996 9.9 hp 4 stroke mercury want to put starter on it, can not find a kit to do it,what parts do I need
Silvertip
Get the parts list for the electric start version and you will have part numbers of the things you need. But basically you need the starter, obviously a battery, mounting brackets if any are used, wiring, ignition switch, overboard kill switch, to name the bigger items.
Doyle
If I were going to do this project, the first place I would hit is the largest independent outboard mechanic in the area. Chances are, he'll have a junkyard motor with all those parts.
