Well to start off, just like the title says, i have a few problems. My boat is a 1990 Searay 200br with a 4.3 mercruiser with alpha one drive... When it ran right it sailed like a kite.
Last year, the last time i went out i started had a hard time starting the boat... It would crank and crank and crank before it would finally turn over and idle for a few seconds before dieing. So i figured I flooded the motor... This went on for about a half hour. After finally getting the boat to stay started i threw her in reverse and flew out the port. I got to open water and finally got her wide open... The only problem was when floored we only got to about 25 or 30 mph... when i first got the boat i could get close to 50....
So any quesses what could be wrong? My first thought was it needed a tune up?
The next problem i ran into the same day was once i came to a stop it seemed like it would start heating up more then normal but once i threw it in gear and got moving it would cool off...
Any quesses what that could be?
Also one other problem when i assume has nothing to do with this whole motor/cooling problem.. The Trim/Tilt works just fine but after a few bumps on the water a few weeks prior to the motor situtation i noticed the quage started reading wrong. I would have the motor all the way up in the air while launching and it would read all the way up but once i tilt the motor down maybe a quarter of the way the guage would read the motor is as low as it could go when clearly it was starving for water..
Any ideas what this could be and could i fix it myself?
