Re: Marine battery charge slowly drops
WhereBob<br />All lead acid batteries self discharge and should be charged at least once a month. The battery voltage should be 12.6 volts at 70 degrees.<br /><br />To start with are you useing a good digital volt meter or the one on the dash. When charging your battery should reach at least 13.8 volts and current drop to less than one amp. Some Automatic charger will charge as high as 14.8 volts. If your charger is not reaching at least 13.8 volts then your battery will likely not be fully charged.<br /><br />12 volt batteries have 6 cells of 2.1 volts each so if your meter is good and your charger is good then you likely have a weak or bad cell in the battery. Check the battery water level if it is the type that you can check. After fully charging check the specific Gravity of each cell with a hydrometer. You can get a cheap one at most auto stores or even wallmart. They will show you if you have a bad cell.<br /><br />You could also put some load on it, Lights, Blidge blower, radio for a while and then try and start your boat. You can here engine crank slow with a weak battery.
