Marine engine vs Automotive engine.
achris
More fish than mountain goat
This document is for people new to repairing boat engines, and who may not understand the differences, or the consequences of fitting non-marine parts (in certain places)...
What makes a marine engine different to its car equivalent?
From the bare block, a marine engine is built up with slightly different parts.
The core plugs are brass or stainless steel, as opposed to steel. And the head gaskets are also non-steel, either composite or stainless. The backing plate and seal in the engine water circulating pump are also stainless steel. This is done because most marine stern drive and inboard engines will be cooled by seawater (salty/corrosive) and not a ‘steel friendly’ coolant. The thermostat in a marine engine is also a lower temperature to try to reduce the amount of disassociation (to acid) that occurs with seawater at elevated temperatures. Marine engine are also required to run under high load for extended periods of time. Unlike a car engine where high load is usually only experienced during acceleration, a boat engine is under high load at all times. Internally a marine engine is also different in that it may use different valve springs, hydraulic lifters and pistons. Even crankshaft bearings can be different. The camshaft profile of a marine engine is closer to a truck or RV engine than a ‘street performance’ engine. Excessive valve overlap, which can contribute to an engine’s higher power output is bad news in a wet exhaust marine engine. Excess overlap can pull water, which is there to cool the exhaust manifolds and gasses, back into the cylinders leading to extensive engine damage. If an aluminium intake manifold is used, then the water passages in it must be sleeved with a material that is less prone to corrosion. Crankcase ventilation must also be done back into the intake side of the engine, lest crankcase vapours accumulate in the boat bilge.
For electrical system components. Unlike an automobile, a boat engine sits in a mostly closed environment. This can allow fuel vapour to accumulate, which if ignited can be very bad. To that end, all electrical equipment must comply with a standard that reduces or eliminates the possibility of a initiating a fire or explosion. Items like starter motors and alternators inherently produce arcing on their commutators and slip rings, it’s just how they work. Screens are put in alternators that allow airflow but will not allow a flame front to pass through. Starter motors are ‘sealed’ to the point where a flame front cannot propagate. Obviously a starter motor can’t be completely sealed due to having to allow for thermal expansion, both of the material and of the air inside. Distributors also can’t be sealed, so the vent on the side of the distributor is a right angle, since a flame front can’t move through a right angle. All electrical equipment on a boat should comply with the SAE-J1171 standard. This also includes the trim pump motors, any circuit breakers, relays and contactors. Fuses are also covered, and are different to a standard automotive fuse. A standard blade fuse has an open base. That is, the fuse element can be in direct contact with the surrounding air. Any fuel vapour present would easily be ignited should the fuse overload and the element ‘blow’. Marine fuses are closed across the base, so there can be no direct contact with the surrounding air. Even things like spark plugs are made of a different material to help reduce corrosion. And spark plug leads must be radio noise suppressed, so as not to interfere with marine transceivers.
Fuel systems. When carburettors were common place they were also subject to ‘marinization’. A standard carburettor vents the fuel bowl to atmosphere, which allows fuel vapour to escape. In a car, that’s fine, the vapour just falls out the bottom of the engine bay and is dissipated, but in a boat that vapour accumulates in the bilge, potentially with serious consequences. A marine carburettor vents the fuel bowl internally, so no vapour can escape. A marine carburettor also has no ‘vacuum advance’ port, but does have another port near the top of the venturi. That port may be connected to a thin hose from the mechanical fuel pump. A standard fuel pump cannot be used on a marine engine because the internal design of the standard pump allows for fuel to be dumped to the crankcase in the event of a diaphragm rupture. In a marine pump there are either 2 diaphragms of different materials with a sight glass between them, or a thin line up to the carburettor port designed for this purpose. In the event of a diaphragm rupture, a large quantity of fuel will be dumped into the engine, stalling it. If an electric pump is installed, it must be wired with an oil pressure switch in circuit, such that should the engine either stall and the key is left on, or the key if left on inadvertently, then the pump does not run. The oil pressure switch will only allow power to the pump when the engine is running. The SAE standard for carburettors and throttle bodies is J-1223.
So yes, your Mercruiser 5.7 is very similar to that 350 SBC engine, but the differences are significant, and there for your safety.
Unfortunate a lot of these differences are internal and cannot be determined by a visual inspection without disassembly. Also, a lot of inexperienced people just pull something like a starter motor out, look at it and say ‘it’s a standard starter motor’, then unwittingly put a non-marine starter in, with dire consequences.
I'm sure I have missed a few things, and comments below will hopefully include those...
Obviously there are many parts that are the same as there automotive counterpart. Things like oil pans, timing gears, chains and covers, valves, head and block castings, oil pumps, vee and serpentine belts, harmonic balancers and water hoses to name a few.
Chris........
altitude 411
Great post Chris.:thumb: This should be placed in the stickies as it seems to come up as a topic so often.
lets add to this.
the magic number is 200F...... keep the block and heads below 200F and you wont ignite things in the bilge and blow you up or burn up your boat
that is why exhausts are jacketed
camshaft duration in a marine engine is kept low, and the over-lap minimal. this is to prevent sucking in water up the exhaust. that phenomenon is called reversion.
for a production based block, there is no special alloy used in marine motors. they all come from GM Industrial engine division. The marine motors are a small segment of the industrial engine group that also contains natural gas engines, engines for fork lifts, trash pumps, generators, etc.
the short block (with the exception of the cam) and heads are identical to the components in a truck. they all come from the same Tonawanda GM plant.
where it gets tricky is the following
6.2 liter, 377 Gen 1 SBC based motors were originally build out the the GMPP parts bin and assembled at Mercruiser/Volvo/Ilmor/Inmar/PCM. these were first used by Mercruiser. after demand went high enough, they would come from GM Industrial (Tonawanda plant). these are a stock GM 350 block that has been clearanced for a stock GMPP 3.75" stroke crank. the block carries part number 88962516. https://www.gmperformancemotor.com/parts/88962516.html
which is part number 10105123 with a few minutes of die grinder work https://www.gmperformancemotor.com/parts/10105123.html
a 377 is a virgin bore 350 with a 3.75" stroke vs the stock 3.48" stroke
a 383 is a remanufactured block with a .030 or .040" over-bore and the 3.75" stroke. these are available via Mercruiser reman or your local rebuilder
the Big Blocks.....
GM never put the 502 in a truck. all 502 8.2 liters are GMPP parts sourced. these are currently Gen VI parts
the last GM BBC in a truck was the 496 or 8.1 liter. this is the Gen VII V8. this motor went out of production in 2010. Mercruiser stopped using them in 2010, and the 425 was a de-tuned 502 using most of the parts from their 525hp 502
Volvo Penta had a warehouse full of these motors and continued using stock 8.1's until about 2017. in the mean time, volvo jumped on the LS motors in 2010 and developed a really good tune for the motors. these are stock LS 6.0 and 6.2 motors these are now being replaced with the current LT motors
Mercruiser did not go with GM LT motors, however designed and casts their own motors loosely based on GM architecture. the V6 and V8 motors with the exception of the 502 are made in-house
4 banger
the 3.0 is still a GM industrial motor offering. the 3.0 is still a stroked and bored variant of the original 2.5 liter 153 cubic inch motor that first debuted in the 1962 Chevy II. the 153 is from the inline family of engines and is a 230 cubic inch engine with two cylinders gone. it was never refereed to as the iron duke. that is the pontiac 151 cubic inch motor. which shares only the 6 bolts holding the valve cover down. the in-line motors share the same flywheel housing mounting pattern as the Chevrolet based V8s
the 3.0 was never in a GM vehicle. the motor was built as a stroked and bored version in the Mexico GM plant for use as a natural gas fork-lift motor. eventually it would be used for marine service. it shares the flywheel housing pattern with the Chevrolet based V8's there are two major designs of the 3.0. 1990 and prior, it was a 2-piece rear main seal crank, and the pistons and rods were from the parts bin shared with early 60's V8s. 1991 and later, its a 1-piece RMS and the pistons and rods are based on the parts for the 5.7 (slightly more machining on the rods)
achris
Scott Danforth I was trying to keep it simple, brief and as an overview for people just starting out, without getting into too much detail on individual engines. And more looking to the safety side of marinization. But, all good information..
I have explained it this way.------When boats are new or newer they are " high value " and the owners do not quibble over the cost of the stuff.---------When boats reach a certain age they end up in the hands of first time owners who balk at the cost of " marine stuff " and do not understand the difference.
gr8shot
As a new boat owner myself, it's been interesting to learn which parts truly are marine specific (alternator, carb, starter etc.) vs which just have marine price tags (oil filters, belts, gaskets etc) Common sense goes a long ways though.
achris
I think an easy rule of thumb is 'can this ... cause a fire or explosion?'. The problem comes with things like fuses, as in the article, often people just don't know there is a difference. And often it not that obvious either.
Chris.......
Agreed, circuit breakers must meet SAE J1171, so should the fuses.
items like carbs, fuel pumps, rotating electrics, water circulating pump, cam shaft, are all marine specific.
Yegboats
Great post! I can't tell you how many times I get asked these questions on a parts counter daily.
