Marine Grade Plywood "LOOK"
tmyers921
I found 7 ply Marine Grade Plywood with No Voids on one side:
4x8 3/4 thick
WWW.PONTOONSTUFF.COM
Marine Plywood
FREE SHIPPING DOES NOT APPLY. CONTACT US FOR A FREIGHT QUOTE ON MARINE PLYWOOD.
Be sure to view the Pontoon Boat Kits - Redeck category to see our complete pontoon boat redeck kits.
Ships in : Ships Within 48hrs
Item #: TP34CCX48PTS1S40
Dimension: CONTACT FOR FREIGHT QUOTE.
Weight: 65 lbs (29.48 kg)
Spec Sheet :
Quantity:
Price: US $65.00
Shipping: Ground ( $0.00 )
ADDITIONAL FREIGHT CHARGES APPLY - DOES NOT SHIP FOR FREE. CONTACT US FOR FREIGHT QUOTE.
4' x 8' 3/4" - 7 ply Marine Grade Plywood.
CCA treated and kiln dried marine plywood for marine or exterior use. Lifetime warranty against rotting and warping. Top sheet has been sanded and all voids filled.
This is the same boat decking used by new pontoon boat builders. CCA treated marine plywood is the only type of lumber which the EPA still allows to be treated with arsenic (a superior preservative), new laws require standard plywood to be treated in a manner that will destroy marine carpeting and hardware (the use of a copper compound rather than arsenic).
Please note that there are dozens of types of marine plywood, if you are rebuilding a pontoon boat and need 3/4" decking this is the proper marine plywood to use.
We understand the difficulties in finding a source for treated marine plywood with these new EPA rules. We always have it in stock but it must be shipped via semi or picked up. Please contact us for a freight quote.
Shopper Reviews
No Reviews Available -
Marine Carpet | Site Map | Google Site Map | Links | Resources | Submit Your Site | ? 2004 pontoon stuff
Gary H NC
Re: Marine Grade Plywood "LOOK"
This needs to be in the restoration forum......
tmyers921
Sorry,,,
I realized that after I hit summit button!
It's posted there too.
Again Sorry,,,,Too many Christmas Parties!
Ayuh,... Once is Enough,... Regardless of Where you post it...
It Ain't even a Post, but a C&P at that....
