Marine Stereo: To Buy or Not To Buy
PondTunes
This is another question that we get over and over and over again:
"Should I buy a marine grade stereo for my boat?"
The answers to this question vary a lot depending on whom you ask. In short it really depends on what your needs are.
1) Some recommend using old car stereos or stereo's pulled out from a junkyard and report great success with them. In the event one fails the cost they had invested was very minimal.
2) Others recommend buying the cheapest one you can find in a super center department store. Again cost being the main issue as it is minimal if something happens to the unit.
It seems with those who cost isn't such a big deal they will go with automotive units that have more features. The big deciding factor between prices on radios now seems to be feature driven. If you want a pretty graphic equalizer or the ability to plug in your ipod then this will cost you more than a basic unit with a simple LCD Display.
The last factor is the environment that your radio will be in. If the radio isn't marine rated it needs a waterproof enclosure to protect it from wet fingers & the elements.
So the real issue is what do you need from your radio?
1) If you need nothing but AM/FM for a little sound then look into second hand salvage radios or superstore specials.
2) If you are wanting more features such as iPod connectivity or SAT/HD Radio then you will need to look at a mid-line automotive or marine unit.
3) When pricing items try to make comparisons based on units with equal features & specifications. Comparing a $45.00 AM/FM/Tape deck to a Waterproof unit that plays DVD's is not any way an accurate comparison.
4) What chance would a non-marine unit have of failing over a marine unit? This can vary on a huge scale. Cabin cruisers with the radio inside the cabin should never get wet and an automotive radio would do just fine.. But on the other hand it would be totally foolish to try to put a non marine unit on a jet-ski.
It all really boils down to there is no perfect radio for every situation. You need to figure out exactly what you want from your radio and let that drive your decision.
bamafutbal
Re: Marine Stereo: To Buy or Not To Buy
try to find a HD radio, ipod hookup, sub out, pre amp outs marine radio for 150-200.00 installed, can't do it.
RGrew176
Depending on where the radio is located should determine which type to purchase. On my boat the radio is located down in the cabin therefore it is not open to the elements such as splashing water, rain etc. I decided to purchase an automotive radio. I ended up purchasing a JVC model KD-HDR1 radio. It is a high definition radio and even my 58 year old ears can tell the difference between regular radio and HD. The FM stations sound like CD's and the AM band sounds like FM. It also has a CD player and is MP3 ready. It is also satellite ready I know you can go with Sirius not sure about XM.
The quality of the radio sound means that someday I will need to upgrade the speakers to take advantage of the sound quality the radio provides.
I am not necessarily recommending JVC although I am very happy with the performance of mine but I do recommend that if you are going to purchase a new radio definitely give HD radio stong consideration.
vandy21
another alternative for the iPod hookup thing, is to use an old or cheap deck with a cassette player, and use a tape adapter, that way you can use your own music, and not worry about the elements getting to it because it was cheap or free.
oops!
good one pond.
thanks for posting that.
i used a cheepie cd/am/fm. in a place where automotive was never supposed to go in a wet marine inviroment. was never happy with it. it was allways going haywire.
my next one im definatly gonna go marine.
cheers
oops
magster65
I've never had a problem with an automotive unit in any of my boats (lots of 'em). I will say though, that if you're in salt water they won't last as long and yes, if they get wet, they don't like it.
My experience is that I've never regretted buying something better than I need but I often regret buying the 'cheaper one'.
vess
I don't know about you all, but I have a hard time hearing anything from the radio when I am driving. The wind and engine noise pretty much drown it out. I suppose using it while parked is a viable option, but I actually prefer the quiet then. Vandy has it right, though- use the cassette adapter on a junky unit if you need the input for mp3. I use it in the car for satellite radio, and it works much better than the FM modulator.
Pursuit2150
A portable radio would be better, I order for you to hear it when running, so will every one else.
If drifting for fish & want a radio, why spend the $$$ for a built-in.
The boat probably needs $$$ in other areas.
MHO
magster65
If I 'crank' my boat stereo... I can't even hear the wind or engine at wot.
Buy a 'real' stereo!
I have to say too that... even though I'm all about crankin' awesome bassy, rockin' boat tunes... consider your fellow boaters. :)
We're of a common pastime!
PondTunes
you probably won't find one like that installed, i don't see you finding a car stereo like that installed either. Since the HD tuner is a separate unit it will have to be mounted elsewhere in the car/boat and wired up. Getting the equipment + installation for $150.00 - 200.00 is asking alot.
You're probably looking at about $275.00 worth of equipment (Radio + HD Tuner) then if you need it installed you're looking at another $50-$100 depending on where you go.
QC
If I 'crank' my boat stereo... I can't even hear the wind or engine at wot. Buy a 'real' stereo!
Yup. My head is slightly above the windshield and I have thru-transom exhaust . . . I have 1000 watts, subs, etc. etc. and can hear mine well enough at 50+ MPH too.
Yup. Right place, right time.
Because of previous experience I didn't think I cared about a sound system on a boat. Get the right one, that will do what you want, and it can greatly enhance your boating experience. If you had said those words to me 3 years ago, I would have laughed. Now, all my boats will have good quality stereos. Everyone in my family feels the same.
rogerwa
What I would like to do is to just wire my ipod into an amp that is hidden. I don't get good radio reception where I am at and would bring any CD on my ipod. So the idea is that I would have a hidden amp with a dash switch and just a plugin jack on the dash. I would plugin in my Ipod,flip the switch and control volume from the IPOD.
Not sure if that would work but that is what would make sense to me..
PondTunes
It wouldn't take very much at all to do that.
Swing by radio shack and they should be able to set you up with the cables you would need to go from the ipod to rca's.. If you're handy with a soldering iron you can come up with some creative ways of adding a nice factory looking jack to your console..
The cable would need to connect to your ipod then convert to male RCA plugs to plug into the amp, wire up your speakers to the amplifiers outputs then just wire the amp up using appropriate gauge power/ground wires to the amp. Next hook up a switch that feeds 12 volts to the remote terminal of the amp to turn it on.
No radio/cd tuner to worry about just one amplified ipod.
QC
rogerwa,
You could get what you want at Radio Shack . . . shoot probably Walmart. Almost any audio accessory site/store will have adapters for this. You can even do it with the Radio Freq ones that plug into a 12 volt plug and then your iPod "docks" into that.
Edit: Yeah, if you're starting from scratch that's cool ^^^^^^
