Ladies and Gentleman,
I have a question on a 34' Wellcraft 3400 Gran Sport. I am trying to determine if I have a water leak (which I suspect) or if the pump automatic shutoff switch on the water pump is bad. The pump runs fine but does not automatically shutoff after running for a long time. I've let it run for about 5 to 10 minutes...but it will not turn off on its own. Pressure builds in the water system but I get water and air coming out of a fitting that is located on the starboard - aft deck area near the floor. The believe the fitting has a male end, as if the female end of a hose would be mated to it, but the previous owner put an "on-off" valve on the fitting. (Please see the attached photograph with a red arrow pointing to the fitting and location. ) Is the fitting depicted in the photograph a water line "out" (for deck wash, etc) or is it a waterline "in" for hooking up shore water via a hose? I get the impression it is a water line out in that it bubbles out water and air when the water pump is on and leaks water onto the deck. Any and all assistance appreciated! Thanks mucho! VB
