mariner ?115 hp ?year everything
fishin420
I just bought a 19 ft open bow mach 1 boat and it came with mariner 80 power trim I think it is 115 hp model is 6393384 I need to know everything I am used to running a little 12ft alum with 4hp me and my boyfreind decided to upgrade so we could go in bigger water for better fishing the motor4 has not been ran for a year the guy did not know the gas mixture year or anything so all you guys could tell me would be helpful.especially on what I should do (i.e.grease,check pump,charge batt.) before we try to start it I am not familiar with large outboards but assume they are alot alike my 4hp just with more hp also we know nothing of the boat either except it might be a 1984-86 19ft mach 1 open bow serial #mv600br ob I think, so any info you could tell me on that would be great also or maybe point me to where I can find out the info thanks<br /> Jodee
mellowyellow
Re: mariner ?115 hp ?year everything
welcome aboard Jodie,<br />the motor is a 1983 marnier 115hp, mix is 50/1.<br />first step is to pick up a manual and read it<br />and learn about the motor. it will describe in<br />detail all reccomended maint. proceedures.<br />good luck,<br />M.Y.
WillyBWright
Follow the fuel line back from the motor to the fuel tank. If there's a plastic oil tank saying AutoBlend on it, eliminate it. They failed often without warning and were the demise of many an engine. Simply mix the fuel at 50:1 as stated.<br /><br />Have the water pump rebuilt! Absolutely For Sure!!! For all you know it could be original and they should never be relied on if they're more than 5 years old.<br /><br />Check the gearlube and change it if it's black, milky, or if water comes out. If it's milky or if water comes out, you'd need to have the gearcase resealed. If the water is rusty, you'd need to have the gearcase rebuilt.<br /><br />I'd also check the compression on each cylinder. A difference of 20 or more psi would indicate a problem that needs to be looked into. As you remove the sparkplugs, look at how they're burning. They should all look about the same. If one or more are significantly different than the others, it may also indicate a problem that needs to be looked into.<br /><br />Good luck and happy boating.
