Hi,
I am a new member. This engine has one problem at about 12- 1500 RPM this engine runs hot.( temp gauge approaches 200 degrees.) If I get the boat ( 18 ft. Searay bowrider 1994.) in a plane the temp drops to about 110 degrees. I have a psi gauge that shows good pressure at all operating speeds. The impeller is less than a year old and the boat is used only in fresh lake water.
I have read about thermostats. I have never replaced these. Where are they located and could this be the problem?
Thanks in advance for your help.
Sullmate
Sullmate
