Mariner 135 stalling right above Neutral ?
xperksx22
Hey i have a mariner 135 that runs great. But sometimes when i drop it to neutral or right above neutral it stalls. It is not all of the time that it occurs but usually once or twice a trip. Just had it tuned up and had compression tests done. Had good compression and everything else seems fine. Has anyone encountered an issue like this ? Possible Solutions ? Thanks.
Chris1956
Re: Mariner 135 stalling right above Neutral ?
Is that a V6 or IL6 motor? Richen up the carbs a bit (a little bit), and see if it gets better.
xperksx22
@Chris it is the V6 Mariner Marauder. All seems to run fine except when i am in neutral or a little above it. It does not stall all the time but sometimes it will go on me. I am totally clueless on this engine where would the adjustment be that will allow me to richen the carbs ?
