I have a Mariner 150 Magnum III 91 / 92 vintage. On the whole the engine has been very reliable but of late we have broken down at sea twice. Once with Divers in the water and 12 miles off, very scary !<br /><br />For some reason the engine just cuts out after period of running, (this just maybe a stall related to the time spent with engine on idle while divers are in water - not main concern). Problem is just lately then engine has not always restarted - issue.<br /><br />We have checked just about everything and replaced the wiring harness which was defective (short when can in contact with water). But lately we have noticed that the battery charging circuit / rectifier may not be working leading to a flat battery. Assumption engine runs on battery for electrical power which decays battery to point where engine fails or unable to start engine after a stall ??)<br /><br />Our instruments are showing 12.4 volts whether engine is running or not ????? This does not appear right to me. I would expect the voltage to be higher voltage output when engine is running and charging battery i.e. 13.5+ V.<br /><br />Question: How can we check the output of the rectifier ? Or check whether the rectifier is working or not ? Is their any values to check ? <br /><br />All ideas welcome. Thanks
