srussell28
- Jul 6, 2004
- 61
Serial Number is 0a195398, model NUMBER 7050625,16 FT Skibarge, Running at 12 mph is as fast as it will go wot. I have 120-123 compression on all cyl, rebuilt the carbs one is brand new, had them adjusted last weekend, have spark on all 4, check all the electrical connections. Someone told me they had the same kind of problem, that it could be the stator, but I don't want to spend 340.00 on the stator and it's not it. Out of the water it sounds good, under a load it runs slooooww. I have new plugs, new tank, new primer ball, new plug wires, switched the coils to make sure they were ok, new starter, Rectifier (this fixed the charging issue), new battery, 1 yr old switch box. The only parts I have not changed are the stator and trigger. Could there be something with the controls? I have controls like this one. http://www.smalloutboards.com/m3586.htm the 3rd pic down. What is the leaver for that you can push in on the top? thanks for all your help.
