Ricky_rich
- Mar 4, 2014
- 146
I have a problem with my Mariner 200 EFI. It loses fuel pressure to the injectors sometimes. I have installed a gauge so I can keep track on the value. And I have now connected an electric fuel pump between the tank in the boat and directly into the VST tank. It gives 97 gp/h liters/min if needed. Was out driving a few days ago and after about 20 minutes the pressure suddenly dropped below 29 psi, the engine stops immediately. Otherwise it is at 35-38psi, moves a little when I press the throttle. Tried another gas tank earlier this summer, but no difference. Have also changed the fuel pump to the injection, no difference there either. Could it be the fuel pressure regulator that is causing the problem? But pressure goes up to 37 and stays there when I turn on the ignition.
I have also done the voltage test on the pump as in the "voltage test chart" below, and all is good. I have plans to connect a voltage meter to the pump and monitor the voltage while driving. (as in test no.6)
