Mariner 200 hp EFI
Troy82
I HAVE A 1992 MARINER OUTBOARD ENGINE EFI MODEL # OD154977 I HAVE NO SPA AT ALL I HAVE DONE CHECKED THE STATOR RECTIFER AND TRIGGER COIL BACK AND WIREING PLEASE HELP ME with ideas to fix it
Troy82
200hp
briangcc
You probably want to have a mod move this into the engine section where you'll likely get more assistance.
roscoe
Ground wires, switchbox, kill switch, ignition switch.
i had the same problem with my 150 xri efi was the ECM sent it out to California they put new boards in it and got it back cranked right up! If you know someone who has a 200 ECM that will let you use it to test with then you can save 750 bucks plus shipping! or do what i am doing to mine right now change it to carbs! i have had so much trouble with the EFI worked great for 20 years but now seems like all it does is give problems now! i bought everything to change mine over on EBAY!
