Mariner 200 - Pictures Enclosed - should this have an airbox?
Superjetjim
Should this motor (Year 2000 Mariner 200HP V6) have an airbox fitted to the carbs?
What is know about this motor type - I'm aware it's a carb 2.5 but nowt more really. Is it much different to my older 81 vintage V6 150 Merc?
Should I bin the Oil Injection or is it more reliable on these newer units? - If so how is this done (short of adding oil to fuel - I assume I need to block off something?)
Thanks!
James
Faztbullet
Re: Mariner 200 - Pictures Enclosed - should this have an airbox?
Yes it should have airbox and pretty much the same as your old motor other than the bigger cubes and higher alternator output. The oil gear is better than the 81 model..
Superjetjim
Thanks for that Faz.
Anyone know what year this motor is - S/N 0G826642
Cheers,
James
Don S
1999
1nebel0
Tons of them available on Ebay... This is a great motor...make sure poppit valve is replaced and check therms unless you know history...Water pump yearly and your good to go...
